Baggers: Cage-catchers / Power-Baggers/ standard 2 baggers
AnthonyC77
  • / Baggers: Cage-catchers / Power-Baggers/ standard 2 baggers
Hey there,
I just bought a 44inch toro Z master (model 74176). bought it used, but it's been a great machine. I currently has a steel cage grass catcher, which is working fine, except for the constant emptying i have to do. Looking at getting a bigger bagging system (maybe a dual or tripple bagger that mounts to the back of the machine).
Is there a major difference between the "powered baggers" verse the standard double or triple baggers, where the grass is basically propelled up the chutes to the baggers? Do the standard baggers clog alot? Worth spending the money on a powererd-vac bagger?
any feed back would be much appreciated.
