Hey, new member here. I have a JD X300 mower, standard side discharge deck and plain off-the-lot blades. I have read several strings here and on Mytractorforum about different options for dealing with clumps and lines after mowing. The problem is that I see a lot of disagreement, and most folks saying what NOT to do, but no consensus on what to do. Some folks say bagging with high lift blades is the best way to go. Others say $500 and it doesn't work well at all. Some say go with the $150 "mulch kit". Others say it clumps as bad as their OEM blades. Some say go with gatorblades, but a lot of folks say NO bcs they ruin your spindles. Then you have the folks with nothing to do but mow grass. Of course it's best to mow off 1 inch of dry grass every 5 days but just is rarely doable for us folks with more work than time. So, I am completely confused and would appreciate hearing your experiences on this issue, and suggestions. Thanks in advance
