badboy mz magnum
ACF
have badboy z magnum bmg5425ko that will not start tested solenoid battery good changed out key switch still nothing. looking to find electrical drawing so i chase wires, when key turned own the pto will engage. which gives me indication safety switches are good. any help would be great and a drawing would help
thanks
AC
do not have 12 volts going to the single wire to solenoid
Try this procedure to identify your problem. Post back with results.
Electrical problems can be very easy or very difficult, depending on four things.
1. How well you understand basic electricity.
2. What tools you have and know how to use.
3. How well you follow directions.
4. You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. You are our eyes, ears and fingers in solving this problem. You must be as accurate as you can when you report back. The two basic tools we will ask you to use are a test light and a multi-meter. If you have an assistant when going through these tests it would be very helpful. These steps work the best when done in order, so please don't jump around. Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and voltage - above 12.5 volts should be good. Check and make sure the chassis ground is clean and tight.
Second, check for power from the battery to one of the large terminals on the solenoid. One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.
Third, check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. If in doubt, remove the solenoid and clean the mounting area down to bare metal. If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch).
Fifth, check for power at the starter while holding the key in the start position (assistant again).
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. At that point we will have great info to tell you how to proceed. Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. If you do not know how to perform the above checks, just ask and I will try to guide you through it. Youtube also has some videos and as you know a picture is worth a thousand words.
One way I have found to eliminate the second person. I have a large wheel weight and set it on the seat. Works great.
One problem is that BB won't anything other than a dang line diagram where as components are not labelled as a switch, relay, and otherwise. They just got an angry email from me as I am completely pissed off about this.
Now what color wire is that solenoid trigger wire? I thinking it is a white wire but not sure because of the stupid line diagram.
Okay traces back thru a control unit (Not shown what it is) not labelled on the schematic. It probably some kinda of interlock module. From there back thru the PTO switch and finally ends at the start terminal of the ignition. With all the time remaining white.
first fuses good, battery connection clean, voltage 12.65
second 12.63 volts from to battery to solenoid
third no voltage on trigger wire have all safety switches overridden
fourth no power on second solenoid going to starter
fifth no power at starter
sixth ground good
if i go from battery to trigger wire the engine will turn over get 10 volts
