Bad Surging 11 HP upright
JoeVB
Hello,
I am having an issue with an 11HP upright B&S engine on my generator.
It has always surged badly when running, I can add choke and it runs slightly better but still bad so I figured its a fuel issue.
I installed this new carb: https://www.amazon.com/dp/B099PQ7WYQ?ref_=cm_sw_r_cp_ud_dp_06FFVG3FCJ40V9R3NCY7
And this fuel pump rebuild kit: https://www.amazon.com/dp/B000A13FBU?ref_=cm_sw_r_cp_ud_dp_HTTBSA7BN27E06W70P3D
But still the same surging as before. Here is a video of the problem: https://www.dropbox.com/s/lt6ubhmewy6i0ck/IMG_1881.MOV?dl=0
Thanks for any help!
Joe-
Scrubcadet10
Moderator
Staff member
get some WD40 in a trigger spray bottle, with the engine running, saturate the area around where the carb bolts to the engine. If the engine, runs better or blows white smoke, or has any change in RPM, you've found your vacuum leak causing a lean running condition.
JoeVB
Thanks! I'll give it a try!
Fuel delivery issue, yes. Dirty carb, yes. Dirty fuel tank, probably.
Dirty cooling fins, most likely.
JoeVB
No change at all when spraying the WD40. I was hoping that would be it. I am thinking about rigging up a temporary fuel source that will feed that carb via gravity to see if maybe the fuel pump is not pumping enough fuel.
JoeVB
I haven't, I never thought about that, I will check.
The carb is brand new and the fuel pump was just rebuilt.
Now you are thinking.
New carb means nothing. Especially if it came from Amazon or Ebay. New carb needs to be tested.
JoeVB
Good to know, thanks. It sure was inexpensive, should have been a clue.
JoeVB
Chinese carb alert!!
You need to ask Bertsmobile1 about his genius carb boiling method. I think this is the best way to clean these small carbs. I tried it once. Got kicked out of the kitchen by this barely 5 foot tall woman.
Will do, thanks! Hopefully you've been re-admitted into your kitchen!
