chrisd1972vw
- Jun 17, 2020
- 3
- 8
I have a Bad Boy ZT I am working on that has major electrical issues. The customer mowed with it and said it was cutting out the last time before he parked it. When he went to start it, it would do nothing. When I went to pick it up the battery was dead, so I put a battery in it and still nothing. I jumped started it over the solenoid, and it started but the deck wouldn't raise, and I had to disconnect the battery to get it to shut off. I have found 4 bad relays, a burnt wire, and several bad connections. The ignition switch also has to be wiggled, but I've tried a new replacement one as well and it still will not start. The solenoid has been replaced as well. Any suggestions? I contacted a local Bad Boy dealer to see about obtaining a copy of a wiring diagram and of course they wouldn't let me purchase a copy. Any help would be greatly appreciated. Also, when you connect the wires to the positive battery terminal, the fuel shutoff solenoid starts clicking even with the key off.
