Bad Boy 2010 4200 MZ zero-turn mower stops
Ted_S
Bad Boy 2010 4200 MZ will only start with parking brake Off and I have to jump solenoid. ?
I mowed my front yard and then moved to back yard. But now when I engage PTO/Blades the mower dies. ?
I can still start with brake Off and crossing solenoid. ?
shiftsuper175607
After you get it started...what happens if you lift your weight off the seat?
Ted_S
I've jumpered the seat switch.
It doesn't do anything with brake engaged and key turned to start. I have arms out and checked that safety switches are pressed in.
I was surprised that it starts and runs with brake off and solenoid crossed.
