Export thread
Backpack Leaf Blower Advice Wanted
#1
shacky
shacky
My smallish Echo backpack bit the dust. Local shop recommended Stihl. The 450 seems too heavy. 350 better. Any other suggestions? The wife like Husqvarna based on Amazon comments.
#2
R
retfr8flyr
Have you considered going gas less? I have been extremely happy with all my EGO products, blower, string trimmer and hedge trimmer. They work just as well and gas powered models without the noise and gas problems. EGO just came out with a backpack model. http://www.homedepot.com/p/EGO-145-...k-Blower-with-5-0-Ah-battery-LB6002/207203612 you should check it out.
#3
shacky
shacky
I don't think that will be enough oomph. I have a ton of trees/leaves.
#4
primerbulb120
primerbulb120
I would go with Husqvarna. I have the 125B handheld blower, I use it commercially and it's blown over 150 yards for me without a problem. Great power, lightweight and comfortable to use. The neighbor has a 125BT backpack, had it for several years with just one breakdown (starter rope broke.) He uses it to blow off driveway, sidewalks, roof and skateboard ramps on a regular basis. I've also read great reviews on the larger blowers and I intend to go Husqvarna for all my handheld equipment.
#5
M
Mad Mackie
The Stihl BR600 is the lightest weight with the most amount of airflow and being a 4 stroke, is quieter than most 2 stroke units.
Although is a 4 stroke, being a dry sump designed engine an oil mix is still needed.
When I bought the BR600, I soon retired the two Stihl hand held units that I had, they were Stihl BG 86 models.
#6
Ric
Ric
I agree with Mad Mackie. If you have a ton of leaves your moving, go with the Stihl BR 600. I run two of them and they can't be beat. The BR 600 runs 677 CFM out with 238 mph at the tube. The weight is only 20.9lbs. They are what stihl calls a 4 mix engine, a 4 stroke which runs on a gas / oil mixture just like a 2 stroke.
#7
RDA.Lawns
RDA.Lawns
If you want a powerful blower. buy the Maruyama bl85 t its 900 cfm at 225 mph weighs about 22 pounds with real nice straps and back padding . I've used mine for over 6 hours straight and wasn't wore out from it. It also has the air share design so your back wont get sweaty Also has a 5 year warranty .
#8
RDA.Lawns
RDA.Lawns
If that's not big enough the new one available for next year is 1100 cfm I have one on preorder be here January the 12th :)
#9
primerbulb120
primerbulb120
Husqvarna 580BTS is 908 CFM at 206 MPH. 26 lbs.
#10
RDA.Lawns
RDA.Lawns
Everyone has their opinion I have gone to all Maruyama can't beat the 5 year warranty . go look at what's available locally see what fits your needs best and buy from a reap able dealer ...my equipment gets used hours almost everyday my needs and yours aren't the same
#11
Ric
Ric
Should have purchased the Stihl BR 700 it's 1550 cfm housing, 912 cfm at the nozzle. $549.00
#12
RDA.Lawns
RDA.Lawns
The new one on order is 1100 cfm at the pipe. After my last stihl product I had stihl will never be a option for me they in my book are now junk
#13
Ric
Ric
Wow I guess Stihl wants to really confuse people now, they rate there blowers in Newtons now.
SPECS ON STIHL BR600 LEAF BLOWER. FORCE IN NEWTONS ....32
MAX MPH 238
CFM 677
WEIGHT 21.6 LBS
SPECS ON STIHL BR700 LEAF BLOWER. FORCE IN NEWTONS ....35
MAX MPH 197
CFM 912
WEIGHT 23.4 LBS
#14
RDA.Lawns
RDA.Lawns
I had a bad experience with sthil product ... Not the same products they once was.....and forget getting a problem solved under warranty .....their exact word to me was I used it to much .....how can a product 18 days old be used to much.....and yes it was a part of the pro line not the homeowner line
#15
Ric
Ric
I guess you had a bad experience by the sounds. Sounds like a dealer issue not a product issue. Thing is I really don't care what the guy buys :) it makes no difference to me. As far as calling Stihl junk goes all I can say is I have the BR 200, 380, 550, and two BR 600s and I've never had an issue with any of them. There the best in my book.
#16
RDA.Lawns
RDA.Lawns
Doesn't matter to me either. Just putting my thought out there . Nothing made today is as good as it use to be before all the plastic and epa carb compliant bs . Gone from buy a product that will last to buy it use it if it breaks chunk it replace it.
#17
primerbulb120
primerbulb120
True, you're probably mowing most of the day while I only do it 10-16 hours per week.
I got the Husqy for three reasons: the air intake doesn't get blocked by the operator during use, it has a good old-fashioned choke instead of Simple Start junk, and it has an adjustable carb so I can tune it to run properly.:thumbsup:
#18
shacky
shacky
So I got the BR700! Wow what a difference from my Echo 265.
#19
primerbulb120
primerbulb120
Nice!! :thumbsup:
#20
shacky
shacky
The BR700 is awesome! A little heavy but when I saw the bigger ones are all within a lb of each other I went with the bigger one.
Buying 6 pack of Stihl oil doubled Warrantee to 4-years.
#21
M
Mad Mackie
Put 3 hours yesterday and 2 hours today on my BR600. Bought it new in Sept 09.
I like how it idles down so I don't blow mulch and small stones as I'm doing leaf cleanup.
I use Stihl premium oil and 93 octane gasoline in all my Stihl power equipment.
#22
OldMasterTech
OldMasterTech
Ditto, I also have two 600's and they move leaves, gravel (after I plow it from the drive into the lawn), snow, acorns and the German Sheperd.
#23
S
sidemouse
Oh Stihl's come out with a br700!!!
I know what I'm buying real soon.
Way I see things when it comes to leaves, you can never have too much power.
#24
stevestd
stevestd
I have had a Stihl backpack blower (BR 700?) for 8 or so years with zero problems; and my hand held Stihl doesn't get used. Don't forget it is not the output speed which is important, but the volume of air it pushes.
#25
S
sidemouse
The 700 just came out, I bought one this morning.
S
stephan
hERE IS THE BEST OPTION _Husqvarna 965877502 350BT~ THE 180 MPH Backpack Leaf Blower with 2.1 HP X-Torq engine IS GOOD FOR HOME AS WELL AS PROFESSIONAL PURPOSES.
#27
A
Aleks
Personally, I'm both hands for Poulan 48cc Backpack Blower ( it has been decently reviewed on gurureviewclub website). Tons of power and get the job done quick. I've had it for 3 seasons without any issues at all
