my mower is backfiring when i shut it off it's a B & S 20 hp twin fire
F freezeplug Member Joined Oct 9, 2012 Threads 2 Messages 12 Oct 9, 2012 / backfire #1 my mower is backfiring when i shut it off it's a B & S 20 hp twin fire
M My_guy99 Well-Known Member Joined Oct 7, 2012 Threads 9 Messages 104 Oct 9, 2012 / backfire #2 Do you have the mower on open choke or a high idle or low idle?
F freezeplug Member Joined Oct 9, 2012 Threads 2 Messages 12 Oct 9, 2012 / backfire #3 it's usually in low idle when i shut it down
F freezeplug Member Joined Oct 9, 2012 Threads 2 Messages 12 Oct 9, 2012 / backfire #4 it has a pull out choke on it the mower was never used much :confused2:. it does surge a little bit when idling. i did replace the plugs as well
M My_guy99 Well-Known Member Joined Oct 7, 2012 Threads 9 Messages 104 Oct 9, 2012 / backfire #5 . You know the basics
M My_guy99 Well-Known Member Joined Oct 7, 2012 Threads 9 Messages 104 Oct 9, 2012 / backfire #6 Don't know why the other part didn't show up but as I was saying! Need to know the basics like model I gather its a vtwin 20hp
F freezeplug Member Joined Oct 9, 2012 Threads 2 Messages 12 Oct 9, 2012 / backfire #7 i'm lawnmower stupid lol haven't a clue what to do .
F freezeplug Member Joined Oct 9, 2012 Threads 2 Messages 12 Oct 9, 2012 / backfire #8 yes it's a V Twin 20 hp 1996 model MTD yard machine
M My_guy99 Well-Known Member Joined Oct 7, 2012 Threads 9 Messages 104 Oct 9, 2012 / backfire #9 Normally it would be your idle speed at shut down, but you say you are in low! And the plugs are new at the right gap setting as well I take it.
F freezeplug Member Joined Oct 9, 2012 Threads 2 Messages 12 Oct 9, 2012 / backfire #10 yes i set them before installing them, i was also told to try letting it idle for 30 to 60 seconds before shutting it down that make any sense to you ?
