My 5hp B&S Eng. Model 135212-0272-01 only wants to run with the choke in the closed position . When the throttle and choke are put to the run position it dies unless I return it to full choke.Please any advise will be appreciated
Sounds like your carb needs to be removed from the tank and given a good cleaning. These two manuals should help you in doing this.
http://www.mymowerparts.com/pdf/Bri...anuals-Parts-List/135200-135299 ms2810[1].pdf
http://dl.dropbox.com/u/12502267/B&S Service Manuals/01_270962SingleCylinderLHead.pdf
