I'm trying to get an old mower running. Model is 917.377130, 6hp. It had very few hours on it, got it from an estate. I put a new carb on it from Amazon. Not sure I hooked up the linkages correctly.
If I push the primer 3 times it won't start. If I spray starting fluid in, it runs fine. I shut it off after running only briefly and have to use starting fluid again. With the throttle all the way on fast/start, shouldn't the carb door be closed to choke it? It's not doing that, its not closing no matter what position I put the throttle in. Thoughts? Is there a video or photos that show me how to hook up the linkages? I tried searching but can't find any good videos. Thanks for any help.
