Hey people. I have an mtd mower I'm trying to fix. It worked when I got it but it seemed like the motor was racing. It shook the flywheel cover screws loose and severed the spark plug cable in multiple places. I ordered a new coil that was listed to replace multiple coil part numbers. The dead one only has the plug wire and a male tab to fit the female kill wire connector. The new part has the plug cable, one black wire stripped at the end and a bare wire with a ring terminal at the end. It doesn't have any orientation markings on it to show which side goes up or down. I've tried connecting it different ways and I don't think its working. I'm thinking I should only need one of these two wires since it was set up before to just use the one it had. Any ideas?
