ron jacobson
- Feb 15, 2018
- 8
I broke the small wire on coil right at the plastic insulation so have no stub to solder a wire on. Replacing coil is confusing because some of these systems have been replaced with a solid state system. I would like to replace coil only. Anyone have part number for original to replace coil only and keep points/ condenser as originally set up. I got a number from JD dealer LG298968 listed as No Longer Available. Anyone had success with aftermarket #298968 such as Amazon?
