You can go to u-tube, type in set governor on B&S mower engine. They have good videos on showing you how. The governor lever has a lock bolt that holds lever tight on governor shaft coming out of the engine. To set governor unscrew bolt to free up lever on gov. shaft, hold throttle wide open, gov. shaft coming coming out of engine will either a slot on the end that a screw driver will fit in, or a small hole at the end of shaft that a small nail will fit in. The object is to hold throttle wide open while turning gov. shaft coming out of the engine clock wise until it stops then lock it with bolt. Hope this helps.
