I have a Husqvarna YTH2348 mower with a Model 440000 23 HP Intel engine.
The engine runs great with more then enough power but will use about 8 to 10 ounces of oil in about 1.5 hours of running time. The engine has about 145 psi on both cylinders and appears to be using only on the right cylinder also the oil is very black and you can change it and after an hour of use it is very black again.
Any options as to what my problem can be. Could it be a head gasket?
