B & S 80202
jb4249
I picked up a roto tiller, Snapper model 300 with a Briggs and Stratton model 80202, type 0510-01. Any idea about what year it might be? I am planning on rebuilding the engine.
Thanks, jb4249
If you look at the Code number next to the model and type, The first two numbers are the year, the next two are the month, and the next two the date of manufacture.
jb4249
The code is 140320. I don't know how to decode that.
Fish
Thanks, jb4249
Why???? What is wrong with it?
jb4249
I scrapped some rust off and you are right. A 1974.
Thanks, Ted
jb4249
Probably not too much. Starter pulled out, tank rusty, carb crusty, and not spark. I would like to get it to running and good looking condition. Probably use it on a go cart or mini bike for my grand son.
TB
A '74 probably has points. I suggest you replace the coil with an updated CDI coil. You won't have to remove the flywheel. Just cut the primary wire and install the new coil. Simple repair to get spark in an old engine.
