B&s 7.75 will not fire
Status
Not open for further replies.
Bruce, you are going to do a lot better than that if you want any help. There are some great techs on this forum, we are not psychic and COVID completely shut down our ESP skills. We need to know the following.
1. What is the make of your unit along with all numbers from the ID tag.
2. What is the make of the engine along with all numbers from the ID tag.
3. When “no crank“. do you mean absolutely nothing happens when you turn the key?
4. Do you have a DC test light or small VOM to test electrical circuits? If yes the first thing to test is battery voltage.
5. Did you replace the old fuel with fresh fuel?
6. What have you done so far to solve the problem.
Answering all these will give us a starting point, if you want help. That’s how this forum works.
bruce1x
Ordered new magento. B&S 7.75 hp on pressure washer. Thanks for reply but figure this will help
Good Luck, as it will be the first time anyone has ever seen the replacing of a magneto has ever solved a no crank problem. Please post back, with your solution, so all the techs on this forum can learn something new.
bruce1x
Replaced coil and works great. May have used wrong word
Status
