silver1
- Oct 4, 2012
- 81
- 415
Morning,
My neighbor gave me this 5 HP Briggs & Stratton off a rototiller as it would not run.
He replaced it with a Harbor Freight motor. Model 130202 3166 01 code 90011227.
I removed the cart./tank and cleaned it all up. Removed rust from inside the tank with
cider vinegar. the owner said that the governor to throttle spring maybe on backward
after he removed the carb.. I need to know if I put it on correctly?
The engine fires on 1st pull, but is slow to respond to any throttle change and it is running
real rich. It will rev up by moving the throttle on top of the carb.
Look and help if you can.
LB
LB
