Sure, you can try telling it to Run Forrest Run a few times. If that doesn't work then clean carb.
Bamm I need to go win the lottery to pay for gaskets. Heads up Expect to pay $80.00 for a carb rebuild kit. after looking through the illustrated parts breakdown I called the "authorized B&S dealer/ listed the gaskets I might need one by one. I like to know how much before I start. some important gaskets can not be ordered individually, the part # supersedes to the carb rebuild kit.
With that in mind I gingerly took the carb apart performing the delicate removal surgery on the gaskets. Now I know some will call me cheap. In the past I had no problem replacing gaskets every time but I never spent more than $20.00. I was able to reuse all but the nasty green bowl gasket. and
Yes the carb needed cleaning (gum deposits in the bowl.)
The machine runs much better but not 100% surging only happens at very low rpm and according to the manual governor is set for 1750 RPM. I may be pushing the mower idle to low. SO I JUST TURNED IN THE IDLE SET SCREW ALL THE WAY IN AND LEFT IT.
Unless its a governor issue I give up. I'll take the 80%
Thanks to all who responded and special nod to the web site maintainers Your all Awesome.
