Captain Slow
- May 23, 2014
- 4
- 11
Hi folks, I've been lurking around this forum for a while and I can tell there are some very knowledgeable folks here. I have a late 70's RER my father bought new with a B&S (8hp I THINK) pull start only engine with the numbers 190702-2190-01 stamped on it. The stickers and other identifying information has long been peeled or burned off and/or painted over.
Anyway the old mower still runs and is just the ticket for my half-ish acre yard, but burns oil like crazy. Ideally I would like to replace the engine with a later or current model engine, but I have not totally ruled out rebuilding what I have. Can anyone point me in the right direction of an engine model that would most easily be adapted to work on this mower (i.e. same footprint, output shaft size/connection type, etc), with a true plug-n-play solution being the best case scenario (I'd happily pay a little more for something that bolts right up to avoid the hassle of trying to adapt this and that), or if I am better of rebuilding what I have. I am not necessarily wed to the B&S brand but this one sure has done a great job over the past few decades.
I have done some digging on the B&S website and they seem to have some 10.5hp vertical shaft pull start engines; can anyone clue me in in 25 words or less (no I'm not counting) what the differences are between the Intek and Powerbuilt engines, and can I expect another 30ish years out of one of these new engines.
Thanks very much for your input
Captain Slow, slowly snapping away and smoking up the neighborhood with my old mower
