B&S 128M02, piece broke off from intake manifold and jammed valve
I lost compression on the engine and when I tore it down I found this little piece jamming the intake valve. I pulled the valve to remove it and reinstalled the valve with no issue. Still in the process of putting everything else back together.
It looks like this is some kind of baffle (to smooth the air flow??), is it necessary? The intake looks to be fine other than this piece popping out, so I don't want to buy a new one just for this. There was also no gasket on the intake, but that's another story. I'm inclined to reinstall the intake as-is and toss this little piece in the trash.
Edit: engine model is 128M02 0412-F1
