Hey guys.
I am currently troubleshooting a swisher string trimmer that is barely firing and then immediately dieing.
It has an auto-choke system that I'm not familiar with. There is no manual choke on the machine, just a primer.
I'm wondering if it is missing a spring. I tried looking at the parts diagrams but could not make sense of it because the parts diagrams included multiple diagrams for multiple variations of the same engine but did a poor job specifying which diagram went with which engine.
I've included a picture. The other reason I'm wondering if this system is working is because the choke is always open, I figured it should start close then open as it runs. There is no muffler bi-metal spring that I can see. Even a quick run-down on how auto-choke works could help me a lot.
I have cleaned the carburetor, checked for spark, replaced fresh gas...I will confess the only thing I haven't done is check that the gas cap vent is working properly, but wanted to get this posting out there because regardless I am really curious as to how that auto-choke works.
Thanks, hope that provides all the info ya fellow gear-heads need. If not I'll reply shortly, and as always hopefully someone else will learn from my experience.
Mod: 126M02-0444-F1
If this isn't the case, I'm going to proceed with a carburetor rebuild.
Mod: 126M02-0444-F1
