B and s twin Cycl model 402437
topcat33
Hi my bolens tractor cut out and I eventually discovered it was the fuel cut off solenoid
I had stripped down and replaced fuel lines and pump.
I have removed solenoid and blanked off but now it only runs on full choke.
, and as soon as I start to close it down it cuts out
Can I assume I have messed with something as I am under the impression that the cut off is to purely stop misfire on shut down, so should have no bearing on the normal running if removed
Thanks in advance
topcat33
Re: B and s twin Cyl model 402437
All sorted now thanks, it was a blocked main jet
Saw Your PM earlier, but at least every body that sees this will know what the fix was. Most people never tell us.
