Post all numbers from engine, thanks.
http://www.ccdist.com/_serviceManuals/briggs/276781.pdf check out this manual & see if it helps.
Do you think this is a Briggs engine? The motor name plate has been scraped and everything is missing except for those numbers. i got it to idle down some today but then it would gallup and shortly quit.
