axle shaft snap rings
Piddler
I just replaced the bushings and seals on my Troy-bilt horse tiller and the first time I took it out the axle slid all the way to the side. I installed new snap rings and I am sure that they were seated. It did not seem that the axle was worn in that area.
Did I miss something?
Thanks, Pete
motoman
Try posting a picture of the axles with your snap rings. Have you looked at a drawing?
Piddler
I had a drawing when I put everything together. It will be a while before I can get any pictures. I probably won't get to check it out until later. Too many other projects right now.
