Attachment lift adjustment question
GaryR
I have just purchased an older JD Model 180 lawn tractor with a 46 inch deck. The attachment lift adjustment (goes from 1 to 4 inches) is loose in the assembly and I am wondering if it is supposed to be spring loaded? I have tried to find an illustration showing the adjustment, but no luck so far.
Also the serial number sticker has been damaged such that it is unreadable. Is there any other way to identify the serial number of the mower?
Thanks for any help.
GaryR
