Atco Ensign B14e no spark
notveryclevertrevor
Hi
I can't get a spark.
Any help please
The coil resistance is reading 15 on 200k setting on multi-meter
It was working fine last time I used it. It's doing my nut in 🤷
Thanks
Probably got electronic controlled ignition and if so you can't test other then Plug and Play; unless, you have very expensive coil tester. Disconnect the kill wire and test if no spark replace the coil. And I am assuming you are using a known good spark plug.
notveryclevertrevor
Thanks.
I've tried 3 different plugs but I don't KNOW they are good 🤷
One is brand new but still 🤷
It is electronic ignition but I don't know how that impacts.
I appreciate your help
