Atco Balmoral 14se
CraigH
I've just been given an atco Balmoral 14se mower that doesn't run and someone's smeared chemical metal all over the carb bowl as it appears to leak, and surprisingly enough, hasn't solved the leak.
I'm wanting to get a new carb for it but need to find the engine code to be able to search for the correct carb. I have the model numbers off the tag on the mower but couldn't find anything on the engine (I haven't stripped it down yet as I wanted to try and get it running to make sure it's a worth while project).
The mower codes are
Typ L80598
579
970000152
1999
Would anyone be able to point me in the right direction to find the engine code please.
If there's any more info needed please let me know and I'll try to pay it up.
