Xxtjtheboater95xx
- Dec 17, 2013
- 1
- 19
Hi guys, been reading these forums for a while now for your great help. This time though, I think I have a unique problem but it could just be a carb problem.
Here's the story
I have been using this mower over the summer, I bought it with a blown engine for a great price with multiple attachments including a snowblower on it right now. I went to start it the other day when we had a big snow storm and it wouldn't start right away and the cranking was pretty slow so I thought it was the battery. I cranked it a bunch of times and the flywheel teeth were a little stripped in one spot but after all those cranks it seemed to strip more and more of the teeth so I had an extra flywheel with a good ring gear. And it did start but I noticed afterward that the starter pinion gear was stripped now, and I think this is because the starter froze in the up position from the really cold weather and it rained and then froze during this whole process.
I also had an extra pinion gear and replaced that last night so that's all good. But still when I try to start it, it will start with a few cranks but only when I disconnect the transmission from the engine with a knob and this allows it to start because it is not spinning all those extra belts.
Still when it does start, it doesn't rev to full speed like it normally does I'm pretty sure because of the sound.
It was last night I started it again with the new flywheel and starter gear and I saw the muffler inside and it was red hot and so I shut it down. It has enough oil and is sitting on a level surface. The redness might be normal, but I just haven't seen it run before at night so I didn't want to wreck it and I just know it wasn't running right in the first place, thinking it might just not be getting enough fuel to run faster and I would think it needs a carb cleaning. But it worked well when it was warm out and only now having trouble. As I was thinking this, I hoped the new flywheel didn't change anything, I mean I didn't weigh them but they look exactly the same and they are both pretty darn heavy.
Ask me any questions you may have. Thank you for your help. I tried to give as much information as possible but I may have missed something.
Here's the story
