Ariens Snowblower attatchment For Lawnmower help.
daltojamesl
Hello, i know this question is going to be very easy for most pf you but I just started leaning this stuff. I received a ariens snowblower attachment for a riding lawnmower or lawn tractor i believe. I cannot for the life of me find anything. Basically if someone could tell me what this thing is worth that would be great. Also if someone could maybe explain how to search the serial numbers that would be huge. I typed the numbers in a number of searches and i cannot come up with anything. Any wisdom is always appreciated.
Model number: 834035
Serial Number: 000123
Gord Baker
  • / Ariens Snowblower attatchment For Lawnmower help.
I strongly suggest that you clean it up and Sell it and buy a large Frame 30" cut Snowblower. That blade on a Lawn tractor requires weights, chains, a lot of room to turn around and will be just a pain to use. It is also slower than a snowblower and leaves banks which cause deeper drifts.
