Ariens S-16H starter problems
ryjacobs
I tried to start my lawn tractor to blow snow and all I got was a single click everytime I turn the key. I checked the battery and it was fully charged. I jiggled the battery cables and starter cables. This time the lawn tractor turned over, started, ran for 10 seconds, and quit (cold blooded). After it quit smoke was coming from behind the dash and the starter remained running until I turned the key off. I turned it over again to see if the starter would stay on again and it did. Any ideas of what is causing the starter to stay on? It is really cold out and I want a good idea of what to try first.
Sounds to me like either a bad key switch or solenoid. Here is a troubleshooting procedure to help you through it.
Electrical* problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch).*
Fifth, check for power at the starter while holding the key in the start position (assistant again).*
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
ryjacobs
I replaced a blown fuse. Other than that, everything else checked out according to your troubleshooting instructions. The tractor started and the starter did not continue to run. What do you think caused to starter to continue to run when I was having issues? Is the solenoid sticking? I am thinking that the starter staying on led to the blown fuse.
For the starter to continue to run it must get it's current through the solenoid. For this to occur either the contact across the large terminals are sticking or the key switch is sticking in the start position. By cleaning the terminals and components (which I assume you did) you may have loosen the tight parts. I agree that the continuous running is a good cause for the fuse to blow, which would lead me to a faulty switch and not solenoid.
