ariens 42" gear tractor. model 93604600. with briggs & stratton motor model 310000 intek i/c.
starts to crank over and stops 1/2 way through truning over. plug is good, gas is full. oil is good.
pulled plug and turned motor by hand to see if it had built up compression. still does the same. any other ideas? thanks for any help.
