i'm having PTO problems on my 10 year old wright sentar. all is fine until roughly 15 minutes into mowing the blade shuts off . everything else keeps running. i've tried a new switch and new relay . at some point i'm going to run thru the wiring and make sure there are no breaks or something loose. is there anything else i should look for ? is it possible the clutch is heating up and shutting down ?
