i have a 2006 17.5 briggs and i am removing the ignition cause of mice.the mower was givin to me and the black and red coming out from under the flywheel im assuming is for the charging system.i plan on a simple wiring system and don't no what to do with these wires in order for it to charge.this is what im going to try and please tell me if im wrong.starter button with two wires.one going to pos batt and the other on the clip to solenoid,neg batt to frame,solinoid to starter,pos batt to the other solenoid post.i don't no where to put the alternater wires red and black
