alternator not working
cpurvis
I engage the clutch on the 14 hp Cub Cadet at very low speed, then throttle up to operating rpm. In fact, it will start the mower turning at IDLE, if the engine is warm. I may be wrong, but I think the additional drag on the engine from amperage used to engage the clutch is minimal compared to what it takes to turn the mower itself.
mcostello
JD 111 original Briggs has an electric clutch.
Mcostello, this thread is 2 years old. I suggest you start a new thread and give us a lot more info on your engine and your problem if you are looking for help.
