algotch3051
- Apr 14, 2015
- 1
I have a HRB216 HXA hydrodrive last fall I hit a tree stump it stalled the engine and now no start. I know that on some mowers when the engine stops like that the aluminum key gets out of shape and now no spark. I took the Honda apart and found the mag wheel is aluminum and the key is steel. I put a dial indicator on to check the travel of the mag wheel before moving the wheel it moves approximately .035 of an inch. Before I purchase a new mag wheel I would like to know if that's what is needed.
Thank you for your help.
