cuckoochris
- Jun 1, 2015
- 7
- 24
Hi all, 2 quick questions. I have a Snapper LT140H33BBV, 33" front engine tractor. I bought it used and it had the bagger attached which I removed and just put on a side deflector. Question 1 is, will removing the air lifts from the blade make it cut any differently? Question 2 is, what type of oil/fluid do I use in the transmission?
Thanks,
Chris
Thanks,
Chris
