New Design Features For 2013
•Simple changeover from mulching to side discharge
•Easy to mow with tighter 20-inch turning radius
•Easy single lever PTO engagement
•Easy mow in reverse option
•Easy to reach height-of-cut adjustment and controls
•Easy mower deck leveling with a single wrench
12.5HP/344cc Briggs & Stratton PowerBuilt 4-Cycle OHV Engine
•Overhead valve design for better fuel economy & less vibration
•Electric start for sure starts every time
Disc Drive Transmission
•Sealed differential and 5-speed on-the-go shifting
•Provides easy forward/reverse drives
33-Inch, Hi-Vac® Mower Deck
•14-gauge stamped steel
•Patented, roll-lip deck for unmatched performance
•Literally sweeps your lawn clean of clippings
•Side discharge, mulch or bag your grass clippings
•Easy to use 6-position height of cut adjustment
