tailgunner
- Jul 30, 2022
- 3
- 9
I have a toro super recycler walk behind that will not run at the proper rpm's . If I rig the idler arm , I can ballpark it around 3000. There is no tension on the idler arm spring and it then runs too high. Something else must not be right because the spring does not control the rpm's by bending the bracket the spring is attached to. Any ideas ?
