Adding lights to Rogue
siraltitude71
Does anyone have pictures of the parts that come with the LED tank-mounted light kit for the Rogue (and other models)? I'd like to add lights but certainly not worth spending almost $300 on their kit. I can get a set of LED pod lights for $50 or less and wire it myself. I assume since the side plate where the lights mount is frenched into the gas tank that the BB kit comes with some stand-off spacers to add room between the plate and the tank for the wire to run? I'll either drill holes in the existing metal plates or fab my own plate to replace them.
Thanks!
Did you ever figure out what lights they use on the kit or what you ended up going with? My Rebel has the Bulldog Logo plate already on the tanks and I was going to get the lights and mount them on those plates.
