Adding LED light bar to rider mower without lights
spta97
I recently purchased a Troybilt TB30R for my small yard.
http://www.troybilt.com/equipment/troybilt/tb30-r-neighborhood-rider
Love the mower, but would like to add a LED light bar for night mowing.
I'm familiar with 12 volt wiring but haven't done this on a mower.
Can anyone tell me how I can size the light bar as to not draw too many amps?
I have a multimeter and can measure the running voltage - I am curious how to determine what type of reserve power I have.
My plan would be to wire from the battery to a relay which would connect to a switch and the light bar. Because it is mostly plastic, I'm wondering if I can find a good ground or if I should use the negative terminal.
Any thoughts or suggestions would be appreciated!
Once I can figure out the acceptable draw, I will likely get the LED light bar off of amazon.
Thanks!
Thanks!
look at this recent thread...
http://www.lawnmowerforum.com/hustler-forum/28029-added-some-led-lights-my-raptor-sd.html
Thanks. There was no mention in that thread about amp capacity but I posted there.
If anyone else knows how I can measure for sizing please let me know.
Thanks!
