Just looked at the 61" rear discharge deck on the Cheetah on the Scag site and from my experience with Hustler rear discharge decks, I see a difference in the basic design that concerns me.
The Scag rear discharge deck is setup like three separate right turning mowers discharging into a common chute with the separation baffles extending all the way to the end of the chute.
My older Excel Hustler 60" rear discharge machine, (1994 machine), had an oblong deck with three right turning blades, no separation baffles, but an easily removed discharge chute that needed to be cleaned frequently.
My current machine, a 2012 Hustler X-ONE 60" rear discharge machine has a triangular shaped deck with the left and center blades right turning and the right blade is left turning. This setup evacuates grass clippings very effectively out the rear with minimal accumulation.
Just my spin on these things!!!
something but haven't found anything that everyone says works 100% of the time. And, if I wash it out each time, I think it would be better than leaving it to rust away my deck. Also thought about building a ramp or wash pit to drive up on and wash it from the underside. I've got to get that stuff out somehow because it affects the cutting ability and lift of the grass.Hi stanhastheplan,
I must say that I have never seen that much buildup under a mower deck!
The erosion on the blade tips indicates beyond a doubt that they are way past worn out. I'm not sure if new blades would solve your problem, but it sure would help.
It appears that you have a very damp lawn.
I have never found any product that reduces accumulation.
Are you mowing with the engine at full throttle?
If you were to install washout fittings, you would need three, one on each separate section.
What is your approximate ground speed while mowing?
I have a similar problem with my Hustler X-ONE rear discharge deck blades and it is from sand and dirt erosion because of the nature of the area mowed.
I have had the operator raise up the deck height several positions which has reduced the blade tip erosion somewhat, but still need to replace the blades fairly often.
Mad Mackie in CT:smile::biggrin::laughing:
I bought the rear discharge thinking it would make life easier when going around the house, trying to keep the grass blowing away from the house. It works very well from that prospective, never have thrown a rock and busted out any glass since, but it does like to leave a nasty little trail of grass when grass is thick. But, it's not near as much grass that would be thrown out of a side discharge. I think it must be cutting the grass much finer and it appears that each of the three blades has a separate chamber for grass. My biggest issue is all of the build-up under the deck after mowing. It will fill each blade circle full. (After my first season it was completely full). I've thought about trying to re-coat the underside of the deck with View attachment 25945something but haven't found anything that everyone says works 100% of the time. And, if I wash it out each time, I think it would be better than leaving it to rust away my deck. Also thought about building a ramp or wash pit to drive up on and wash it from the underside. I've got to get that stuff out somehow because it affects the cutting ability and lift of the grass.
Let me know your thoughts....once again, I had very little build up, if none on my side discharge Yazoo/Kees 52" deck. It was awesome in that regard,,,,,except it ate bearings. Gonna try and post some pictures.
OMG!!!!!!
That looks like a picture from a lawn horror movie. WOW!!!!
I'd install 3 wash ports and fab up a triple hose/single connector setup ASAP.
WOW!!!!
Yes, me also. That's crazy!
You should email SCAG and see what they recommend. Maybe they would provide a a recommendation. (Maybe next years model would have was wash ports installed.....)
