edward beday
- May 17, 2019
- 1
- 5
I am trying to add a starter to this engine, Briggs and Stratton model 202412. It has a type 0163E1. the flywheel presently installed has a casting number 214924, it looks like it could use a shrunk on type steel starter ring gear but it does not have a gear. Is there a ring gear for this flywheel? Failing that, can anyone supply a flywheel with integral ring gear?
