Accessing inner rod bolt
tim4
I am replacing connecting rod on a Kohler 21 horse courage engine but can't get socket on inner rod bolt. The counter weight balancer is not allowing me to get a socket and wrench on the bolt. The engine is model sv600 spec sv600-0009 serial 371311993
hlw49
Service manual says to turn crank shaft so rod journal is at 9 o'clock.
tim4
I finally got it. I used a short socket on a small swivel extension thanks.
tim4
I was wondering what to torque the replacement rood too thanks.
