ac 130 all wheel steer transmission problem
bal55
Please help! Have a new ac 130 aws 23 hp b+s twin since start thought we had a trans problem, only 3 tanks of gas thru machine. reverse seems strong, forward seemed to have a pause then a guick re engagement . Now seems to even pause 1 to 3 sec. then will go forward. This is on level ground, worse on a slight grade. The lock out to push mower seems to be ok and completely disengages.
Any ideas are a great help.
We still have warrenty, but are looking for an easy fix.
Thanks!!!!
I know what you mean about trying tio find a quick fix, but seeing it is under warranty take it in. That way you still have the warranty if anything else should happen. you can always talk to the mechanic afterwards, to see what was the problem
