I have been getting a few PM's about my Kommander so I thought I would offermy thoughts after a year.
I put about 25 hours on it before I started off this season, I have done a oil, filter & air filter change. And I have replaced a set a blades for the start of this years mowing season.
I have removed the ROPS bar, and truthfully if you have a flat surfaces to mow...jerk that thing off and don't look back.
I have installed a Cyclone Rake on it for the fall clean up and if you get the hang of driving the thing...is the cats meow.
Would I buy the same mower... you betchababy. No questions asked, when I look at other ZTR's in the same range...I just smile, ya one of the stupid grins, like you did it right and who cares type.
Why...
Eeeee-Gads the power. Many will poo-poo the Kohlers, not me. Over half what I mow is a field that can get tall. This thing makes it with no problem.
THE FREAK'N CUT... It's just GREAT, 1800 rpms and that deck even makes my field looks beautiful let alone my lawn.
Speed vs power vs quality of cut. I can drive this thing as fast it goes at 2-1/4" cut and it amazes me how well it does.
I love the upgraded seat. I have seen some comments about the ride and the ones commenting don't even have a Kommander. ANYONE that has a mower in this range, it's not going to be a Cadillac. If you have a rough area, it's going to be rough...HOWEVER, I do believe this this crazy thing does a great job especially with the upgraded seat.
The ease of maintenance. It doesn't get any easier. Oil change is just plain stupid easy. I was about to buy a lift to get to the deck but I was able to drive it up on the lip of the diveway (about 4"), with the deck up, it gave me plenty of room to change the blades.
The deck. I love the way it is made, totally flat on top, you can get in clean. Thick, tough and simple. I had weird thing happen, branch got into the top of the deck and into the pulleys, jammed it ALL up. Had to kind of reset everything, piece of cake. In the past I had floating deck, I like this deck better for some reason, at least for my conditions.
Odd things I like. The deck raising mechanism and cut length adjustment, I just like the way it works, really simple, no big honking chains, straight forward. The cut in the frame to let the oil drip from the filter when you pull it off. The lift assist, after it got broke it, it really helps (ya I know I hated it in the beginning). The fuel consumption is great vs what it does...I swear It's better than my old 17hp Kawi. The mower just looks great, set it next to a BB and you see what I mean, well finished.
What I don't like...
It's mainly around one of the things I really LIKE...IT'S THE POWER. First that deck, at 1800rpm's it is LOUD. THEN the amount of dust, you do need a mask when it gets dry. The other thing has nothing to do with the mower, the local dealer. When I went to buy the blades this year, I asked what type/weight of oil do I use...the sold me some SF, I believe it asks for a minimum of SH or SJ. They said I would need a impact wrench to remove the blades, nah a simple 18" breaker bar did it with ease. Sometimes it seems they are a bit weak. Good people, I would buy from them again. In the beginning I tore up a lot of grass, but it was just a learning curve on my part.
Parting thoughts...
I know it sounds like I just drunk a bunch of cool-aide. This thing really runs well, cuts the grass with out going over it a second time and the bottom line it saves me time. I just enjoy driving the thing as I mow. If you get a Kommander, you are getting a good mower. I'm sure it's on par with others in this range, but over all if it fits what you like and the feel is there...buy the darn thing.
Those that are looking at the Komander (or what ever mower for that matter). TALK to people that have one...NOT cyber readers that look at boards/review sites all day and give you opinions. This purchase is TOO much money for you not to do that.
If you have any questions...PM me and I will get back to you as soon as possible.
Stay safe out there... MIKE
Why...
Parting thoughts...
