A very cheap NEW two post lift.
PTmowerMech
It says is rated for 10,000 lbs. Half that would be more than I'd need. $699.
Aston 2 Post Car Lift 10,000lb Two Post Auto Lift *SINGLE LOCK RELEASE High-End
ModelAL-100RH
Capacity10000 lbs.
Max Lift Height72″ (1830mm)
Minimum Pad Height4.33″ (110mm)
Overall Height147″ (3720mm)
Overall Width135″ (3430mm)
Width Between Columns111″ (2820mm)
Drive thru Clearance104″ (2650mm)
Lifting Time40s (Adjustable)
Lowering Time30s (Adjustable)
Column Thickness of Steel0.24″ (6mm)
Carriage Thickness of Steel0.24″ (6mm)
Arms Thickness of Steel0.24″ (6mm)
Motor Power3.0kw
Voltage220V 1ph
Noise<70db
Net weight2101 lbs. (953kg)
Gross weight2145 lbs. (973kg)
Packing size147″ x 18″ x 30″ (3720x460x750mm)
Pump Packing size36″x12″x14″ (900x300x350mm)
Features: 220V 60HZ 1PH 3HP MOTOR
PTmowerMech
I'd have to find a way to shorten these. My ceiling is only 8ft tall.
7394
I'd love a lift as well in my senior years. But ceiling is also limiting factor.. Arrgh..
Boy those prices are very attracting tho..
PTmowerMech
I don't think I'd go cheap if I was using them as a car lift. But a mower lift, I'm sure they'd be great.
7394
Valid point, not a time to cheap out. . I put my mower up on car wheel dollys in winter, so I can easily scoot it around, & easily get under it, but on my back on the creeper.
If you read further down on the website it says to contact them to get the correct price because the listed price is wrong and the sale cannot be completed on the website
7394
Doh, it's always about reading the fine print.. I'm good how I'm set up for my private use world. Just dreaming..
KM Richards
These cheap ones look like offerings from ye olde CCP, purveyors of the El Cheapo line of products!
