I have a Sears L1000 riding mower.
The battery was replaced with one that has cold crank amps as opposed to the original that did not have cold crank amps.
Can I switch from a standard 30w motor oil to a 10w-30?
I live just outside of Richmond, Virginia where the weather is not that severe and I don't intend to use the mower in the middle of winter.
Thank you.
Chuck
Thank you.
Chuck
