PTmowerMech
- Apr 16, 2018
- 438
- 3,353
Getting those cable loose can be real trouble sometime. So, I made this.
Grind out a slot in the socket. Then welded a handle to it on the other sides. Slid it on over the wire cable, press it down, and the cable comes right off.
Seems like it was a 9mm I used. Works awesome. A lot better than needle nose pliers. The first pict is what I use it for.
