- Sep 24, 2017
- 254
- 6,494
Got the aformentioned model, 9P702-0001-B1 (plastic carb) 799584
cleaned carb, got the main jet assembly cleaned good, fires up first pull, when it gets hot i begins surging.... I put a new O-ring where it mounts to the intake. still surged when warmed up.
sprayed WD40 around, no leaks around the intake, but when i hit the base of the throttle shaft it would bog blow a little white smoke... there is some play back and forth in the shaft... i would say more than usual on a better metal carburetor.
it appears there is no repair kit with a new throttle shaft or bushing, so i guess i need to purchase a new carburetor?
