GeneG
- Apr 29, 2012
- 1
- 3
Hi, A friend of mine gave me 2 stroke 10323 that he did not used for several years.
I filled with mix and it started, only one problem a lot of smoke. So I realized that I did not mix it right. Anyway, I brought for a repair/tuneup to a local garage type shop. Got it back with a new plug, sharpen blade and correct mix for $62 and a recommendation to mix it right.
Brought home, it started well and run for 15 min, and died. Waited for couple min, it started again worked for couple min only this time, reved up and died again. So now it hardly starts and if does works for couple min that revs up and dies. Any suggestion before I will bring back to the shop? Thanks
